please advise. Kicker GT 2 ground terminal mounting.
  • 2
Sand off all rust or paint. Self tapping screw or nut/bolt will work with washers.
Personally, I'd drill a hole and use a bolt with a lock washer or lock nut and sinch it up tight
thanks adulbrich.
thats what i was leaning too.
Another quick question... that block has 2 terminals.. my battery connectors also have 2. i have 2 amps.
I was going to have 1 run from lug to battery... and 1 to my sub amp.. directly to the frame.
The kicker battery terminal also have 1 4ga lug... i was going to run that to the body in the back.There is a factory body ground nearby...
does all that seem pretty efficient...
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
726
Check out Sonic Electronix as well. They have some great deals usually and excellent Customer Service also. I like to buy my HUs /Head Units from...
646
rlowride
rlowride
Florida
adulbrich
    Jun 15, 2024
    Jun 15, 2024
