jdubbau
Ok I have had this unit installed and they did have it grounded instead of to parking break sensor. However it did not work as I would get the message of you cannot access this while car is in use.
I tried rerouting the ground to a few different spots one on the actual chassis that when I just tested it with wire touching ground and temporarilly mounted it worked fine. I then mounted it then it would not work. Remounted and did testing again worked perfect 3 times or so after verifying and turning truck on and off.
Then I have tried to use the unit since and it acts like before and will not bypass. Am I just not grounding to a good spot well enough or is the deck just picky on grounds and not the correct way to bypass?
Any info would be very helpful as I do see bypasses on ebay to buy if I have to.
