Fuses!
You guys are silly. Take the fusing on your amp, divide that by 2. Divide that number by 2 and then add it to the number you got that from.
Example:
Amp = 120A
120/2 = 60
60/2 = 30
60+30 = 90
Use a 90A fuse
Also, rub your power wire down with cooking oil and it will increase the current and decrease the overall amperage. All the pros do it.
Bwahahahahahaha
Example:
Amp = 120A
120/2 = 60
60/2 = 30
60+30 = 90
Use a 90A fuse
Bwahahahahahaha
Now THAT'S funny. 4 AWG is rated for 95 amps. How you got so close with that formula is beyond me.
4 awg cable is rated at 110 - 150amps, so I have no idea where you got 95amps from //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Its called the National Electrical Code (NEC). 95 amps max enclosed (not free air) at 86 degrees F ambient. It goes down from there. Any further questions?
http://www.coastalelectric.com/Reference/NEC310-16.html
michaelholey
Sturgeon Bay, WI
McIntosh
