G g_dogg Junior Member 3 0 canada Oct 7, 2006 #1 I have a Pioneer AVH-P5700DVD that has MOSFET50 4-Channel Amplifier. the sub i have is MTX thunder 10 inch sub (T4510-04) 225 watts rms. my question is? can my head unit run this sub on its own or do i need like a 200watt amp?? Click to read more...
azimuth 5,000+ posts funded*by*soros 9,662 8 Denver, Co Oct 7, 2006 #5 mtx makes a decent amp. thunder 202, i think is 250 watts rms
OP G g_dogg Junior Member 3 0 canada Oct 7, 2006 Thread Starter #6 whats the best way to install it? connect amp to the preamp outputs? i think the other way is tap in the rear speakers?? sorry guys need help i know nothing about car audio
azimuth 5,000+ posts funded*by*soros 9,662 8 Denver, Co Oct 7, 2006 #7 you need a set of interconnects (rca's) to run from the back of the deck to the amp
OP G g_dogg Junior Member 3 0 canada Oct 7, 2006 Thread Starter #8 i assume i need a wire to go from the amp to the battery as well?
mattmcss 10+ year member Shake that laffy taffy 4,447 2 Twin Cities Oct 8, 2006 #9 i assume i need a wire to go from the amp to the battery as well? Click to expand... Is this your first time ? You might want to have a shop do it, but yes you will need to run a fused power wire from your battery to your amp Bcae1.com is a good source for your questions, and should get you going in the right direction.
