Rasheedhos
Banned
How do i by pass the parking break option? can i just connect the green wire to the ground of the radio?????
ok toggle switch to Head Unit and then what ground to the switch? The ground from the harness?Doesnt the 5700 need to see a pulsed ground before working? ex: parking break on,off, on. i could be wrong as it has been awhile since i have touched that unit. if it does you just need to add a toggle switch to it
Wouldn't it work if you just connect it to the radio ground from the harness?no a toggle switch from the parking brake wire to the switch to a ground, but what i normally do is connect a relay inline for things that need to see a pulsed input.....
You're a dumbass.
it's a 94 mustang, so how would i go about doing it, how many wires are there on the parking brake? which one am i takeing to the toggle swith? after i get that wire hooked up to the switch i ground the swith and then connect the switch to the Pioneer green wire?its already been said a toggle switch
Look at post #10 tard.it's a 94 mustang, so how would i go about doing it, how many wires are there on the parking brake? which one am i takeing to the toggle swith? after i get that wire hooked up to the switch i ground the swith and then connect the switch to the Pioneer green wire?
ThanksSimple toggle switch.
It has two wires.
One wire connected to ground, other wire connected to the green parking brake wire.
I've done countless of these.
nG
You're a dumbass.
Why do you think that? I said yep, because he asked if he could, and of course he can, unless he has no hands. If it would work or not was not part of the question. Either way tho, you are going to call me a dumb ***, so i'll just leave it at that.You're a dumbass.
that cause you are a dumbass...Why do you think that? I said yep, because he asked if he could, and of course he can, unless he has no hands. If it would work or not was not part of the question. Either way tho, you are going to call me a dumb ***, so i'll just leave it at that.
