Pictures :)
Glock23
il
My system isn't in the car yet.
Why it took so long:
Negative Ground for battery:
Blue field wire still needs loomed up but you can see it here.
yep 4 rib to a 7 rib pulley O well if it lines up, it lines up. Can you get larger pulleys for the rest of the stuff and go up to 7 on all of them? that would be sweet and no slippage
It's an EA alternator and I will be doing a review on it soon. It's 200 amp.
The pulley was that way with the old alternator so I'm guessing it's fine. Don't know if I can get bigger or why I'd need bigger.
Thank you. I did all the crimping looming and wiring my self then zip tied it all //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I turned a wrench a little bit too. It just too a while because we did it right.
nathan puts those oversized pullys so you can adjust it and make it line up perfectly. no need for a larger belt. I had a 300 amp alt running on a 3groove honda belt and it didn't slip //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Glock23
Glock23
il
Glock23
