Phoenix gold ZX475ti zeropoint amp
in perfect condition with extremley good sound quality and lots of options to run your system.
Was thinking $250 obo (I know the paper says $300 in the pics as I originally planned to ask for a little more for this amp)
Continuous Output Power at 1% THD (Wrms):
ZX475Ti
Into 4 ohms Stereo @ 12.5 Vdc (IASCA/USAC) 18 x 4
Into 4 ohms Stereo @ 14.4 Vdc 75 x 4
Into 2 ohms Stereo @ 14.4 Vdc 150 x 4
Into 4 ohms Bridged @ 14.4 Vdc 250 x 2
Minimum Speaker Load, Bridged 2 ohms
Minimum Speaker Load, Stereo 1 ohm
Recommended Fuse Size, Stereo 4 ohms / Stereo 2 ohms / Bridged 60 / 80 / 80 amp
Continuous Current Draw @ Full Power * 60 amps
Peak Current Draw @ Full Power ** 85 amps
Dimensions, Chassis (inches) 15.00 L x 9.00 W x 2.25 H
Dimensions, Overall (inches) 16.00 L x 10.00 W x 2.25 H
Total Harmonic Distortion
Signal to Noise Ratio (A-weighted) > 100 dB
Frequency Response +/- 1 dB, 20 Hz to 20 kHz
Bass Boost 0 to +18 dB @ 45 Hz
Crossover Frequency Range 40 Hz to 8 kHz
Crossover Slope 24 dB per octave
Input Sensitivity 200 millivolts to 6 volts
Input Impedance > 30 kohms
Input Voltage Range 0.2 volts to 6 volts
Power Supply Operating Range 10.5 Vdc to 15.5 Vdc
Typical current draw at idle
*Average continuous current draw when playing typical music material.
**Average peak current needed for musical peaks (
US Amps Hybrid Tube amp Tu-600c
In extremley good condition besides a few deep scratches but as you can see in the pics the amp needs to have the plexi mounted up to show off the internals and tubes.
$420 Obo Shipped in Con US
165 Watts x 2 @ 4 Ω
300 Watts x 2 @ 2 Ω
600 Watts x 1 @ 4 Ω Bridged Mono
S/N >95 dB
Damping Factor >600
Vacuum Tube/ Transistor Hybrid Amp
SAT
No Global Negative Feedback
Class A Type Circuit
RD Audio Sonance 10" V.1 Dual 4 ohms
I have 8 of them in NEW like condition as they have been used for less than 2 hours.
These love small boxes and will do well in SPL ported enclosure at only .8 cubic ft and great for daily or SQL at 1-1.25 cubic feet ported. Does not take much to get them going either but can handle 500-700wrms depending on your application.
X1-$90 shipped in con us
X2 $170 shipped in con us
Contact me if you want all 8.
Ready and boxed up to be sent your way.
jdubbau.gross@gmail.com is my pay pal id and best way to contact me.
Elemental Designs 3.6 (6.5" Subs)
Work perfectly and are in good cosmetic condition
These will really suprise lots of people as if put into the right enclosures these can be pretty crazy sounding for 6.5" subs.
$100 takes all 3!
I am up to some trades but really only interested in TC Sounds LMS or other 4" coil subs, DDZ1, DDZ1a,DDZ2lv, DDM3, DDM4
Pics!
Picasa Web Albums - 11416917151367128... - Audio sale stuff [/url]
ZX475Ti
165 Watts x 2 @ 4 Ω
300 Watts x 2 @ 2 Ω
S/N >95 dB
Damping Factor >600
SAT
$100 takes all 3!
Pics!
