Phoenix Gold TI Series Amps.
Used for 3 to 4 months mostly just sat in my car (my car was not a daily driver). These are in like new condition and work flawlessly. Selling because I sold my car. Condition would be a 9.5 out of 10 for small scuffs/scratches. These amps are underrated and will make more power than what they are rated.
TI 800.4 POWER RATING:
200 Watts x 4 Channel / 2 ohm
125 Watts x 4 Channel / 4 ohm
LOW PASS RANGE
40Hz to 400Hz
LOW PASS SLOPE
18dB Octave
HIGH PASS RANGE
20Hz to 400Hz
BASS BOOST
0dB min to +18dB max
HIGH PASS SLOPE
18dB Octave
POWER TERMINAL
1/0GA
FREQUENCY RESPONSE
20Hz to 20kHz (+/- 1dB)
SIGNAL TO NOISE RATIO
Greater than 110dB
HARMONIC DISTORTION
Less than .01%
EFFICIENCY
50%
DAMPING FACTOR
Greater than 200
HEATSINK THERMAL MASS
10.5 grams per mm
DIMENSIONS
20.4" L x 9.8" W x 2.5" H
TI 2500.1 POWER RATING:
2500 watts x 1 @ 1ohm
1500 watts x 1 @ 2 ohm
LOW PASS RANGE
30 to 300Hz
LOW PASS SLOPE
24dB octave
SUBSONIC RANGE
10Hz to 55Hz
BASS BOOST
POWER TERMINAL
1/0GA
FREQUENCY RESPONSE
20Hz to 300Hz (+/- 1dB)
Greater than 90dB
HARMONIC DISTORTION
Less than .1%
EFFICIENCY
80%
DAMPING FACTOR
Greater than 200
10.5 grams per mm
DIMENSIONS
$450.00 each, for the 2500.1's
$350.00 for the 800.4
No shipping charge if picked up. I will send shipping quotes if needed. Tracking numbers will be included.
Pictures for 800.4
Pictures for both 2500's
Amp 1
Amp 2
LOW PASS RANGE
40Hz to 400Hz
LOW PASS SLOPE
18dB Octave
HIGH PASS RANGE
20Hz to 400Hz
BASS BOOST
HIGH PASS SLOPE
18dB Octave
POWER TERMINAL
1/0GA
FREQUENCY RESPONSE
Greater than 110dB
HARMONIC DISTORTION
Less than .01%
EFFICIENCY
50%
DAMPING FACTOR
Greater than 200
10.5 grams per mm
DIMENSIONS
LOW PASS RANGE
30 to 300Hz
LOW PASS SLOPE
24dB octave
SUBSONIC RANGE
10Hz to 55Hz
BASS BOOST
POWER TERMINAL
1/0GA
FREQUENCY RESPONSE
Greater than 90dB
HARMONIC DISTORTION
Less than .1%
EFFICIENCY
80%
DAMPING FACTOR
Greater than 200
10.5 grams per mm
DIMENSIONS
Pictures for 800.4
Amp 1
Amp 2
