Sold Phoenix Gold RSD2D DVC 12" subwoofer
mvw2
Specs:
T/S parameters(from what I could find)
Re: 3.7 ohms (per coil)
Qts: 0.55
Qes: 0.61
Qms: 5.76
Fs: 22 Hz
Vas: 94.05 ltr
Mms: 178.3 g
Cms: .284 mm/N
BL: 12.43 N/A
SPL: 84 @ 1W-1m
Watts RMS: 500 watts
Xmax: 13.5 mm
Specs are somewhat vague on this sub, very little literature. I modeled this up in Bassbox and had the program guess for a couple of the specs, but for the most part, this is pretty accurate.
Manufacturer's site:
http://www.phoenixgold.com/2004/rsdspeakers.html
I've only had this sub for a short time, a couple weeks. I've heard rave reviews about this sub, so I figured I'd give it a try. They ended up not being quite what I was looking for, so these are moving on to whoever wants to see if this little best is right for them.
$100 OBO
i got 6 pg octane zr //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif same motor as the radial but diferent cosmetics.... kick *** subs for themoney awesome sq outperforms even the underground brands sq and decent loudness... 2 rsd with 800 watts 144.9 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
completly different sub, RSD>Octane in every aspect
i have both dude..... ill take the rubber thing on the pg and same motor //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you have no idea what you are talking about the zr is more like the tantrum x, please visit phoenixphorum.com and read up on the rsd before you make another misinformed post
Adding a few pics.
These are the parameters for the DVC version provided by PG.
Re 1.85/parallel
FS 22.4(Hz)
Sd 0.0483(sq M)
BL 8.503™
SPL 84.2(dB)
Qms 4.72
Qes 0.63
Qts 0.55
Vas 95.948(cu M)
Cms 289.58(uM/N)
Mmd 168.60(g)
Xmax 13.5(mm)
VC 2(in)
What's your best offer so far?
mvw2
mvw2
Rochester, MN
mvw2
