Sold PG ZPA 0.5 New Pics **1000+ at 1,2, and 4 ohms**
DWancha
Repost of my PG ZPA 0.5. 10/10 mechanically...8/10 cosmetic. The plexi piece is cracked on three of the four corners and can no longer be screwed on. I do still have it though and if you know someone who does plexi work another one could be made.
Lowering the price to 300 since there were no bites at all last time I posted.
4 ohm stereo @ 12/13.8 VDC
150/300 WRMS x 2
2 ohm stereo @ 13.8 VDC
500 WRMS x 2
4 or 1 ohm bridged @ 13.8 VDC
1000 WRMS x 1
Frequency Response
+/-1dB from 20Hz to 20kHz
Signal to Noise Ratio
>100dB
Input Sensitivity
200 millivolts to 2 volts
Input Impedance
>10k ohms
Input Voltage Range
10.5 volts to 15.0 volts
Typical current draw at idle
750 milliamps
Minimum Impedance
1 ohm bridged/.5 ohm stereo
Dimensions, ZPA 0.3
13.9"L x 13"W x 2.1"H
Dimensions, ZPA 0.5
15.9"L x 13"W x 2.1"H
DWancha
DWancha
Olympia, WA
DWancha
