Peak @ 42hz but sweep is 52hz!?
frkkevin
Ok.. I'm not sure what this means exactly. My box is tuned to 35hz but peaks at 42hz. When I run a sweep it says my note is 52hz, but that is incorrect. Does this just mean that my car peaks around 52hz and I need to tune my next box to 42hz?
Trying to break a 150dB here.. 146.3 @ 42hz just is not cutting it for me..
Yes it was all a TL.. but when I burped at 52hz my score was dramatically lower than at 42hz.. Before I resined my box and did a double baffle my box peaked at 45hz.. and the sweep matched. Now after those mods the sweep is 10hz higher than where I actually peak.. confusing to me
I see.. I normally run my sweep at 18 (burp at 26) so I can save my charging system.. think that is why it was off?
Btw.. know any information for a 2003 Jetta.. about where it peaks. If I could ge that info it would save me a hell of a lot of trouble //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
42hz .. yeah I'm the one competing in TBP org.. I'm on a quest to break that 150. I was going to try to do it with the single sub setup I had but I'm just gonna toss in another 35.1 and SX 15" ... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i peaked in the backseat of my exgirlfriends //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
well 42 is your resonant freq.
Im pretty sure the resonant frequency of the Car is alot higher than 42...thats just where his current setup is peaking at.
If I were you man, I would build a box that brought your note up into the 50s maybe around 52-54. You should see a gain in a trunk car...of course it wouldnt sound as good as a daily box, but you would get louder on the mic.
lmao.. I think I can do it.. With my current setp doing 146.3 .. adding 2 of everything I had.. another 1500rms.. and another SX 15.. in theory that is a 6dB gain but I'm hoping to see at least 4dB..
frkkevin
frkkevin
US
frkkevin
