Parking Brake Override for Jensen VM9312
not sure bout Jensen but Most are just a ground. some are on a timer, and like my clarions once you turn the unit off it likes to see a interupt in the ground. (toggle switch) or relay which ever you prefer.
it has to see a ground, non ground, then a ground.
I have the bypass code upstairs that works on pre 07 models tho //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
heres the trick to the parking brake bypass procedure:
1. Go into Am/Fm mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
p3bumpin
p3bumpin
Brier Hill, NY
matrxx dude
