PAIR OF MINT RE AUDIO SE 10s
cleansoundzz
2 RE AUDIO SEs dual 2 ohm models with boxes
  • Nominal Impedance -Znom: Dual 2 ohm
  • Thermal Power Handling -Pe: 600 W
  • Force Factor -Bl: 17.7
  • Electrical Q Value -Qes: .46
  • Mechanical Q Value -Qms: 4.4
  • Total Speaker Q Value -Qts: .42
  • Free Air Resonance -Fs: 26.6 Hz
  • Equivalent Compliance -Vas: 31 liters
  • One-Way, Linear Excursion -Xmax: 18 mm
  • Efficiency - SPL 1W/1m: 83.2 dB SPL
  • Effective Piston Area -Sd: 310 cm^2
  • DC Resistance -Re: 2.8 ohm
  • Mounting Depth - 6”
  • Mounting Hole Diameter - 9.25”
  • Overall Diameter - 11”
  • Bolt Hole Circle - 10.125”
  • Motor Width - 6.25”
  • Motor Depth - 3.25”
  • Basket Depth - 2.75”
  • Displacement - .14 cu. ft.
  • Weight - 20 lbs.
  • Dual Composite 2-piece Cone
  • Rubatek Foam Surround
  • Cast Aluminum Basket
  • Tork-Tite Terminal
  • 3" 4-layer Aluminum Voice Coil
  • FEA Optimized Motor Structure
  • Triple Stack Maganets
  • Progressive Spiders
  • Wrap around Rubber Gasket
9.5/10 if not better. They come in original boxes.
$250 shipped in the US only. no trades.
cleansoundzz
cleansoundzz
Buena Park
cleansoundzz
