Sold Pair of Exile x2400.1 Lots of Pics...
Lckmyblls
4 Combat Tours & Counting
I have 6 of these laying around and only need 4 in my spl setup, i was going to use these in my truck but i also have a ab vfl 150.1 im going to use instead.
So these need gone...they still have factory warranty for a couple months yet and come in original boxes with manuals and i also have a extra bass control knob also for one of them.
Pictures speak for themselves put out a solid 2400 rms @ 13.8 volts 1ohm load
Will play .5ohm daily and burp at .35ohms Also are strappable!!
$425 shipped each Firm Thats a steal already as it is or 800 shipped for the pair
http://www.exilecaraudio.com/exile/content/manuals/exile_amp_manual_v2.pdfLink to online manual ....
specs....
Manufacturers specs: 800x1 @ 4ohms / 1600x1 @ 2 ohms / 2400x1 @ 1 ohm
4800x1 @ 2 ohms Strapped / Recomended Fuse: 200 amp
Power/ground: 1/0 gauge Dimensions:16.66"x11.125"x2.625" Big power in small package...
Freq response: +- 1 db from 20hz to 300hz
Signal to noise ratio: >90db
Subsonic and Low Pass Crossover: Linkwitz-Riley 24db per octave
Low pass crossover range: 30hz to 300hz
Subsonic crossover range: 5hz to 55hz
Input Sensitivity: 200 millivolts to 8 volts
Lowest Recommended load: 1ohm
Damping Factor: Greater than 200
Typical Efficiency: 85%
Lckmyblls
Lckmyblls
Fort Campbell Ky.
Lckmyblls
