Painting Interior Plastic
Selvos
14
Europa
HI I need to refinish some plastic pieces in my interior. It was custom painted blue, but it has been chipping, it's not smooth, and some areas just look bad.
I wasn't the original owner, so i'm not sure what they used. As far as I can tell though, the paint was an OEM toyota blue. Problem being that it was made for metal, not plastic.
So my first question would be if I need to add a flex additive to the blue.
I'm also confused about the differences between primer and adhesion promoter.
My plan is this:
Strip old paint with ?
sand
SEM soap
SEM plastic and leather prep
Plastikote plastic primer
Blue with flex additive?
SEM color coat satin clear
This is my first time doing this, so I don't know all the steps. Do I sand after primer? What else should I know?
does plasti dip come in OEM colors?
Not oem as far as I know but you'll probaly be able to get close.you'll still need to prep well.home depot or lowes has all sorts of paint removers,strippers that you brush on and it will literally make the paint gel up and wipe off.pretty messy but effective.that will get you back to original plastic.
Ok another question:
does anyone know what I should use to thin the paint to be able to spray?
I need something plastic safe
During my replacement of a factory sub I had my factory plastic enclosure just sitting in the back with my new sub just sitting in it loosely and...
Selvos
Selvos
Europa
Selvos
    May 16, 2024
    May 16, 2024
