thatkidbob
bondo filler is OK. you can get good results with it, but it sands like ***, and you'll usually get pinholes no matter how careful you are with it...
the bondo glaze is the same way... its so hard to sand that you can often introduce new stuff that you need to get out while trying to sand it...
For your next batch of filler and glaze, buy evercoat... after using bondo you'll REALLY appreciate spending the extra bucks to buy it off the net...
me too... i musta been on crack when i wrote that lol... basically, as long as you take your time, fix all the errors, and you aren't afraid of going back a few steps to remedy a problem, you'll end up with a good finish...Well i guide coat after i primer the first time and sand it all down til the blacks gone
haha, yeah my eye is only ok... i don't paint just a whole lot. i can only spot the most egregious errors without a guide coat... if you don't need it, skip it by all means, because it CAN be problematic to use paint as your guide coat...but that's coming from a trained eye that can see all that stuff without guide coat.
