P880-PRS or P980BT
Trey803
GAMECOCKS
I am getting one of the two for my B-day in 3 weeks and need help choosing. I was first attracted to the p880-prs b/c of the auto eq and 16 band equalizer but when i found out that the other one has that also and color screen, I become interested in the p980BT. I plan on using it with the sirius tuner if that makes any difference at all. Which one would yall recomend?
From an audio stand point I would go with the 880. It has independent left and right 16 band EQs. The auto eq is worthless in my opinion. I've owned several Premier decks and will no longer use that function.
If a color screen is a must the 980BT wouldn't be a bad choice either. Its just that the 880 is a better unit sound wise. Especially if you wanted to go active.
Why do you think the auto eq is worthless? And what does purpose does the independent L/R equalizer have?
Most people (not just me) don't like the results of an auto eq setting. Just ask around this forum and you'll get the same answers. It just doesn't leave a good sounding curve. You're better off to set by ear or an RTA to start with.
The purpose of independent left and right EQ is so that you can set the left seperately from the right side. The right side of your is not the same as the left side of your car acoustically so this eq lets you adjust them independently.
If auto Ta/eq is not that important you may just save money and go the 780, its has the colour screen you like but without the the bluetooth of the 9800bt. The 880 is a really nice unit though.
Sounds good but I do not think that i have heard enough SQ setups to tune by ear and may be challeneing for me.
What is an RTA?
If the color screen is important to you, get the BT - if you want what is in my opinion the sleekest, most functional headunit on the market under five hundred dollars, get the 880PRS.
Sounds good but I do not think that i have heard enough SQ setups to tune by ear and may be challeneing for me.What is an RTA?
Real time Analyzer, allows you to see the audio frequencies and the dips and peaks. You can then adjust EQ to make a flat response.
If it is for personal/casual use, I think you should just adjust the EQ to your liking and not worry much about his.
Just like danz24 said. But you don't have to be competitor to benefit from an RTA. I demand the best sound out of my system whether I'm competing or not. A flat response is not really a GREAT sound as it will sound like there isn't enough bass and too much highs. What an RTA will do for you though is leave you with a good starting point in which to tweak it to exactly how you like your music.
I had the same dilemma a couple of months ago. I got the 980bt 'cause the color screen and the bluetooth is the shit! The 880 looks **** good, but the 980bt is the latest and greatest from pioneer. - just my two cents.
Exactly, just depends on what you're looking for in a deck.
Trey803
GAMECOCKS
Trey803
SC
lamont1
BP1Fanatic
BP1Fanatic
