Sold Own a piece of Ngsm13's History
Darren5531
Here is your chance to own a little bit of ngsm13's history. This subwoofer was featured in this reconeing thread as seen on this site.
Mainly looking for trades on either a active head unit, 1 or 2 subs depending on what kind and maybe a 4 channel amp. I would love to get a pair of idqs/idoems, diymas or dayton ho's. Here is how ngsm13 himself would describe the woofer.
It would be on par with a W7 and IDmax... and it's very efficient.
I would put it right at 50/50 sq/spl... a great SQ subwoofer. Excellent SQ, with great output due to linear displacement.
I'd put above the performance of an oldschool SI Magnum
I am wanting $220+exact shipping. This is a steal because whatever ngsm13 touches automatically jumps up to a $500 value.
Specs:
15" Custom Black Ash 12 spoke Basket
Dual 2ohm 3" Voice Coil
Dual Stiff Spiders
Zinc Plated Push Pin speaker terminals
26mm Xmax
Revc = 3.4800 ohms
Fs = 31.6602 Hz
Zmax = 42.0942 ohms
Qes = 0.6016
Qms = 6.6755
Qts = 0.5519
Le = 3.7553 mH (at 1 kHz)
Diam = 365.1250 mm ( 14.3750 in )
ConeArea =104706.3470 mm^2(162.2952 in^2)
Vas = 116.1551 L ( 4.1020 ft^3)
BL = 19.3946 N/A
Mms = 330.7339 g
Cms = 75.4348 uM/N
Kms =13256.4746 N/M
Rms = 9.7239 R mechanical
Efficiency = 0.5907 %
Sensitivity= 89.7134 dB @1W/1m
Sensitivity= 93.3285 dB @2.83Vrms/1m
Saved the best for last pictures:
//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif Even with ngsm13's own seal of approval.
Power wise you should be great anywhere from 600-1300+ rms but only go that high if you know what your doing. 900-1200 rms would be optimal in either a nice 2 cube box with some poly fill or a nice ported box would make it sing. Yes Hawaiianbasshead Ngsm13 said he would probably rate it above an old school magnum because of the copper wires and upgraded suspension.
looks like a no name brand.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
and who is this guy who owned it? is he some sort of *********?
Darren5531
Darren5531
Iowa
Darren5531
