snyderd758
Specifically focal p165 v30 they are being powered by a mosconi gladen 240.2. I set the amp at 120 watts per channel with a 1000hz 0db tone. When I play them at the max volume that iset the amp at they will cut out. No bass boost the eq is set the same or cut never any boost.
I was thinking maybe there is some kind of protection built into the crossover? All wiring is tight brand new rca's and voltage is good. What else could it be? Thanks in advance.
