OS Sony, Rockford, Elf Audio
5.3bowtie
Sony XM-4026
Rockford t4004
Elf Audio E1500DM
The Sony is in good condition cosmetically and mechanically. I was going to use it on some tweets but am going a different route. These are suppose to have great sound and I am actually using 2 of the 4 channels in my build.
Specs:
1-8ohm stereo, 2-8ohm bridged
Rated @ 14.4V:
55 x 2 @ 4ohm, 0.04% THD
80 x 2 @ 2ohm, 0.1% THD
85 x 2 @ 1ohm, 0.1% THD
160 x 1 @ 4ohm, 0.1% THD
High Pass: 80hz, -12db/oct
Low Pass: 50hz, 80hz, -18db/oct
The Rockford is in fair condition cosmetically with a few nicks on the black heat sink but I think it may have internal problems. I was getting intermitant alternator whine that just occured randomly and then went away. When I removed the amp and hooked a different one up the problem went away. Not sure whats wrong. Also, it is missing the cover plate.
Specs:
25 Watts x 4 @ 4-Ohms
50 Watts x 4 @ 2-Ohms
100 Watts x 4 @ 1-Ohm
100 Watts x 2 @ 4-Ohms Bridged
200 Watts x 2 @ 2-Ohms Bridged
High-Pass (HP): 40-400Hz 12db/Octave Butterworth
Low-Pass (LP): 40-400Hz 12db/Octave Butterworth
Bass: 0dB to +18dB @ 45Hz
The Elf Audio is nearly BNIB. It is in very good condition and is a nice amp. I ended up needing power at 2ohm instead of 1ohm so this is no longer in the build plans. Love the small footprint though.
Specs:
200 x 1 @ 4 Ohms
340 x 1 @ 2 Ohms
500 x 1 @ 1 Ohm
Minimum Speaker Impedance 1 Ohm
THD Distortion 0.1%
IMD Distortion 0.1%
Input Sensitivity 0.1V ~ +2V
Input Impedance 20K
Signal to Noise Ratio 85dB
Gain Control 0.1V~+2V
Low Pass Filter 40Hz-180Hz
Bass Boost 0dB ~ +9dB
Fuse Rating 40A
8 Gauge Terminals
Width: 5.1" (130mm)
Height: 1.65" (42mm)
Length: 8.25" (210mm)
Sony: $70 Shipped
Rockford: $65 Shipped
Elf Audio: $140 Shipped
All Prices OBO!!
Shipping will be through UPS unless buyer decides otherwise.
Sony:
Rockford:
Elf Audio:
Bump. PM's replied to. Lets get these gone! Make me an offer!!
Will do partial trades + cash on my part for active HU's and 8 ga. power/ground wire as well as 12 ga. speaker wire.
5.3bowtie
5.3bowtie
Detroit, MI
5.3bowtie
