orion
at woofersetc.com you can get the orions for i think $65.. im just lookin for a temporary system that i can have sounding at least better than the stock sound... will i notice much of a difference with the orions??
ok... ill look into that... would it sound better with 2 subs or just 1... the reason im interested is because im planning to build a sub box in my shop class and i need to find out which sub im gonna get so i can build the box around it
Just look at the space u have to fit the box in Cubic ft wise and as far as the sub goes
if you get that amp, It will run 600watts rms at 1ohm so you can run 1 or 2 of whatever
size sub you chose. If you run 1 sub make sure the voice coil is a dual 2ohm so that you can get the most out of that amp at 1ohm..If you buy 2 subs make sure there dual 4ohm's each so
u can wire them down to 1ohm also. If that didnt make any since here is a subwoofer wiring
calculator
This is for 1 dual 2ohm sub wired at 1ohm
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22
This is for 2 dual 4ohm sub's wired at 1ohm
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
Pdrollinger130
Pdrollinger130
Hoopeston, IL
Pdrollinger130
