Just want to know how to get the most power out of it. Is it 1200w x 2 @ 2 ohms, 600 x 2 @ 2 ohms, or 2400 x 1? I was running 2 15" H2's in a sealed box built to spec, and it was quiet! Could hardly even hear it outside the car turned all the way up..,actually the rattles were louder than the bass. I had it wired like this: negative from amp to negative of voice coil, positive from same voice coil to negative of other voice coil, positive of that voice coil to the positive on amp, and same w/ the other channel. Is this right for 2400 watts? Sure didn't sound like 2400 watts even with the trunk open, maybe half of that.
Basically this is how they wired my amp at the shop, from "looking at the amp's speaker outputs point of view," and they are dual 2 ohm voice coils:
sub 1 sub 2 sub 1 sub 2
Is that correct for a 2 ohm load?
no problem....and it still isnt loud?Ok, right now all "4" outputs are being used. The subs are wired the same internally, but they are individually wired the the outputs, so I'm not sure if that's the same thing (I think so). Thanks for the help.
No, well my amp blew shortly after I had it installed...then that caused my subs to blow!!! I recently got the amp back from repair, now I need to send the subs in. Then I guess I'll find out. I'm going to build a ported box in the mean time.
