Orion XTR Pro 12" ???
I think i found the right specs
XTR 12 Specs
Nominal Impedance 4.0 ohms
Re (DC Resistance) 3.6 ohms
Levc (Inductance) .85 mH
SPLo (Reference Efficiency)@2.83v 92.57 db
Fo (Free Air Resonance) 23 Hz
Qms (Mechanical Q) 2.52
Qts (Total Q) .468
BL (Force Factor) 7.29 TM
SD (Cone Area) 0516 sq. meters
Vas (Compliance Volume) .309 cu. meters
Xmas (Linear Excursion) 10mm
Pt (Thermal Power Handling) 800 watts
Mounting Diameter 11.125 inches
Mounting Depth 5 inches
Basket Displacement 209 cubic inches
Voice Coil Diameter 2 inches
If this is right would i be safe with 1 cu. ft or what would be a safe size?
skate21221
skate21221
San Francisco, CA
skate21221
