Sold Orion Hp2800
infamous_e46
hArRy_DaNgLeRs
I just recieved this amp in a trade with us3 and i was going to keep it but i blew the :verymad:engine on my h22 accord:verymad: so i need monies
it is a pretty solid 2 channel
Orion HP2800 Features
Orion industrial heatsink with illuminated logo
Mil-Spec double-sided circuit boards
Massive loosely-regulated MOSFET power supply
Patent-pending ESP port
Digitally programmed input voltage
Control over turn-on delay
Input sensitivity lock-out mode
Anti-theft and valet modes
On-board self diagnostics
Control, program, and read using the DEI BitWriter™ or PocketWriter™ (available separately)
Variable 50-500 Hz low-pass or high-pass crossover
INTELLiQ bass optimization
Variable 0-10 dB INTELLi-Bass equalization
Variable 20-150 Hz subsonic filter
Satin finish direct-wire power and ground connections
Optional HP-RB1 remote bass level control
Full CEA-2006 compliant specifications
HP2800 Specifications
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 125W x 2
THD at 4-Ohm RMS Power:
Bridged RMS Power @ 4 Ohms: 400W x 1
Speaker Level Inputs: yes
Preamp Outputs: no
Built-In Crossovers: HP/LP
Bass Boost: 0-10 dB
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 77 dB
Fuse Rating: 2 x 30 amps
i have found it for sale on ebay and onlinecarstereo
http://cgi.ebay.com/Orion-HP2800-Car-Audio-Amplifier_W0QQitemZ330222784784QQihZ014QQcategoryZ18795QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16579
The first 80 plus shipping and p.p. takes it
cellphone pictures i took this evening
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
