Sold Orion Hcca's & Hifonics 2608 Amp
greywone13
$875 SHIPPED!! have on smd.com also.
I have 2 12.2" Orion HCCA's. One is brand new, never used. The sub is back in the original box for shipping. Also comes with a 2 week old (still hasnt been broken in) Hifonics 2608d amp (also back in the original box). I have the original box, bass knob, and manual for it. All the equipment works great! There are NO scratches or marks on the amp (just wire hair in pics). One of the subs has some scuff from when the audio place built my box for them.
I have a box that is built to specs that fits a 99 Gmc sierra extra cab for an extra $100. You could Cut the bottom off if you wanted the box as well. It's like a little stand, hard to explain. I can send you more pics of that if you want to see closer.
About the subs:
Power(RMS/Peak) 2000/4000
Fs (Hz) 36
Qts .53
Vas (cu ft) .812
SENSITIVITY 84db
LINEAR EXCURSION 30mm
DIMENSIONS (in) 11.9 x 10.7
4” copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
Continuous power handling will be 1500W (under rated)
Peak power handling: 10” 3000W 12 & 15” 4000W
Burp power in excess of 4000W on 10” and 5000W on 12 & 15”
X-Max estimated at 30mm (total travel 4” peak to peak)
Field Replaceable Cone / Voice coil / Spider Assembly
Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
Enhanced voice coil cooling system (forced convection – aluminum heat sinking – shorting rings to reduce inductive heating)
About the amp:
BXi 2608D 1 x 850 W @ 4 Ω / 1 x 1700 W @ 2 Ω / 1 x 2600 W @ 1 Ω
amp hasn't been broken in yet , bah!
gain and bass boost maxed out!
There is no such thing as "breaking in an amp", but with those kinds of settings.... breaking an amp is very possible!!!
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
greywone13
greywone13
Huntington Beach, CA
elnegga809
