Sold Orion, Eclipse, Carpet, Kinetik
CrazyKenKid
Idems for sale: All prices are SHIPPED and OBO
1. Piece of carpet - $15
2. Orion 4002 - SOLD
3. Eclipse DA7122 - SOLD
4. Kinetik HC600 - SOLD
5. Orion 2500D - $425
Specs:
1. Piece of Carpet
2.5' x 5' (sorry not accurate i jsut used my size 11inch foot to measure, no tape measure)
2. Orion 4002
RMS: 100 x 2 @ 4 Ohm
Peak: 200 x 2 @ 2 Ohm
Birdged Output: 400 x 1 @ 4 Ohm
Signal To Noise Ratio: 100 dB
Frequency Response: 20 - 20khz
Built-In Crossovers: Yes
Ohm Load Stability: 4 Ohm Bridged
Low Level Input: Yes
Built in Cooling Fan: No
Bass Control Knob: No
Dimensions: 18.4"L x 10.5"W x 2.3"H
3. Eclipse DA7122
Amplifier: Mono Channel
RMS Power at 4 Ohms 500 W x 1
RMS Power at 2 Ohms 1000 W x 1
Frequency Response 4 Hz - 3000 Hz
Signal to Noise Ratio 120 dB
THD at Rated RMS Power 0.01 %
Low - Pass Frequency 50 Hz - 200 Hz
High - Pass Frequency 50 Hz - 200 Hz
Other Features
Input Voltage 10.8 volt
Dimensions 16(L)x12(w)x2(H)
4. Kinetik HC600
AGM Technology
Sealed Non-Spillable Design
Mount In Any Position
Ultra Low ESR
More Plates For Stronger Energy Density
Higher Voltage Under Load
Tightly Packed Cells
Superior Heat & Vibration Resistance
Weight: 14 lbs.
Ah: 20
Amps: 850
Dimensions: 7" x 3" x 6.5
5. Orion 2500D
1 X 1200 @ 4 Ohm
1 X 1700 @ 2 Ohm
1 X 2500 @ 1 Ohm
Frequency Response 20 Hz - 200000 Hz
Signal to Noise Ratio 80 dB
THD at Rated RMS Power 0.9 %
Crossover / Equalizer
Low - Pass Frequency 30 Hz - 250 Hz
High - Pass Frequency 10 Hz - 150 Hz
Other Features
3 Way Ready No
Dimensions
Width 27.2 in.
Depth 10.5 in.
Height 2.3 in.
The Reason for selling:
This was just left over and I no use for it
Used it once to power 2 6x9 pushing 80rms to each one. No need for it now.
Got this just to try out against 2 sae 1000d amp(strapped 1800@2ohm)! suprizing it did the job quite well but I have no need for it now! (some ppl say this puts out 1800rms at 14.4 volts i say around 1750rms but then agian who am i to say what it does)
Got this to do some bench tests on ampliers! I finished my bench testing so I don't need it any more
Purchased this with INTENT to use turns out I now need money BAD, I HATE to see this go but I need some coin what can i say!! The last guy who had this was using 2 of them to power one sub (1 orion 2500d on each coil of the sub) the sub was a duel 2ohm so he was only using 1700rms on this amp!
PICS:
would you trade the 2500d and a little cash for my kenwood excelon ddx-8019 double din? its 2 months old.
VERY temping!! give me till tuesday and i will let you know for sure!!
i also have another offer going for another amp but a double din HU lol! is awesome
CrazyKenKid
CrazyKenKid
Canada
sikcavy
