Orion Amp
i'm new here and i don't know why i shouldn't use caps but i wanted to know which wires i needed to use coming off my amp tho bridge it.
Instead of using each channel, which is a terminal on your amp that has a +/- and a +/-, you just run both of your positive speaker wires into one of the + amp terminals, then run both the - speaker wires into the other - in the same channel.
caps means you're yelling....
anyways...
the amp should ahve it labelled which terminals to use for bridging...
its one of the positives, and one of the negatives...
according to teh Orion site - use the orange wire for positive, and the black yellow wire for negative, then push IN on the MONO button...
codySEGURA
codySEGURA
LA
Wonderbread
