Orion 2NT 10"
Lurius
Well, I just picked up a couple new subs today that I bought on Craigslist.org
Lol, now anyone got specs on these guys? All I could find were the specs to the 12's which are below. If anyone has the specs on the 10" let me know, i'll appreciate it very much!
Specs
Secifications Parallel Series
Nominal Impedance 2 Ohms 8 Ohms
RE(DC resistance) 1.6 Ohms 6.6 Ohms
Levc (Coil Inductance) 1.3 mH 4.53 mH
Sensitivity @ 2.83V/1m 93dB 87dB
Fs (Free Air Resonance) 22 Hz 22 Hz
Qms (Mechanical Q) 6.56 6.56
Qes (Electrical al Q) .46 .46
Qts (Total Q) .43 .43
BL (Force Factor) 8.2 TM 16.5 TM
Sd (Piston Area) 500 sq cm / 78 sq in 500 sq cm / 78 sq in
Vas (Volume Acoustic Suspension) 134 Liters / 4.77 cu ft 134 Liters / 4.77 cu ft
Xmax (Linear Excursion) 10.52 mm / 0.41 in 10.52 mm / 0.41 in
Power (Continuous Thermal Power Handling) 500 Watts 500 Watts
Power (Peak Thermal Power Handling) 1000 Watts 1000 Watts
Outside Diameter 12.5 in / 318 mm 12.5 in / 318 mm
Mounting Diameter 11.125 in / 283 mm 11.125 in / 283 mm
Mounting Depth 5.75 in / 146 mm 5.75 in / 146 mm
Basket Displacement 244 cu in / 4.0 Liters 244 cu in / 4.0 Liters
Voice Coil Diameter 2.5 in / 64 mm 2.5 in / 64 mm
Enclosure Recommendations
Sealed Enclosure Volume 1.00 cu ft / 28.3 Liters
Vented Enclosure Volume 1.70 cu ft / 48.1 Liters
Port Diameter (Inside Diameter) 3 in / 76 mm
Port Length 11 in / 279 mm
Gonna go hook'm up and see how they sound in a little while(its 107F outside right now =X)
-Lurius
Well, I got the specs from Orion and finished wiring and installing the subs into a sealed probox. These eubs only have a 4.75" mounting depth, which rocks because my box is only like 5.75 inch deep, previously I had trouble finding subs to fit.. Diamond makes one, jl makes a couple, and aparently orion =).
Anyways, wired it up, 2ohm stereo. They definantly hit hard, though my amp isn supplying them with 500w each, so they arent nearly as loud as they want to be.. only getting about 800 or so total. Definantly a butt massager.
-Lurius
Yea, just went for a drive and man they sound nice. I think my JL was a little clearer, but im having my doubts on that as well. besides, these have a really nice cast aluminum basket, definantly heavier duty than my JL with the stamped steel basket. What I want to know is how much these can handle, realisticly, not the spec sheet handling.
-Lurius
Lurius
Lurius
Arlington, Texas
Lurius
