Sold Orion 2500d's, 18" TC Sounds 4HP, cda 9813
KngOfThePkngLot
Banned
well, im bailing on the stereo idea so im going to be getting rid of everything...
2 Orion 2500d's
my.php
1 18" TC Sounds 4HP
1 Alpine CDA 9813
shoot me some offers, need to get rid of everything by tuesday...will trade for an in-dash only.
that box might be a bit extreme but don't get rid of the sub before you try it out first
i really dont want to get rid of it, but the problem is i only have another $750 i can either get the alt.($260 from excessive amp.), a battery($150 optima yellow top), and a simple wood ported box($250 from a local shop..has to be built inside the trunk)....or i could do the fiberglass box($550) and have the $200 left over...the other thing i was thinking was just running it sealed and having the other $250 lef tover from the box and buy a set of comps...decisions, decisions
if your going to keep it port it, wood box, and you'll need a alt, battery for any big amp .. what amp would you use since you sold the other two? 2000 watts would be plenty for daily.
i can get a ported wood box 5ft^3 w/ 110^2 in. of port for $250..the alt. is $260 and the battery is $150 so i would have enough to do that.....i will be using a 2500d...im just going to use the other 2500d since everyone who says they are going to buy it backs out.
if your going to be using the sub daily i'd go smaller port something like 75 sq in or something.. I had 175 for both in a wall setup for spl
so you would do 5ft^3 with 75^2 in. of port?...could i do 4ft^3 with the same amount of port or would that be too small?
I'd keep it at 5 cu ft .. 4 cu ft is the smallest I'd go but thats for more spl then anything .. It will be loud as hell in the 5 cu ft box but if you want more sq the smaller port will be better for you
SQ is the least of my worry's:D my goal is to be in the high 140's low 150's in a trunk set up with 1 2500d...f*ck everything else:laugh:
KngOfThePkngLot
Banned
KngOfThePkngLot
NY
KngOfThePkngLot
