Sold Orion 2500d MODDED!
Spkrman
Banned
Overvoltage protection removed (modded), which doesn't effect the amp in a daily beater.. and if you feel the need to get more power you can run it on a 16v system.
Has a few small scratches, nothing major. I definitely have one end cap, the other one is in the garage somewhere, I should be able to find it before shipping.... but honestly the amp looks better without the end caps.
One of the strongest and most effeciant amps period... you don't need the retarded electrical you do with most other amps that throw out this sort of power.
Actual power output.... note very few amps I've tested are even capable of doing rated power... let alone double //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
.5 @ 12v - 3200-3500 watts
1 @ 12v - 2000-2500 watts
2 @ 12v - 1000-1600 watts
.5 @ 16v - 4000-5000 watts
1 @ 16v - 2500-3000 watts
2 @ 16v - 1300-1900 watts
450 shipped //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Paypal accepted, just cover the 3% they eat.
?? Not familiar with this specific "modded" amp. Seeing he is from Team PHAT HERTZ he probably uses it to compete.
That I did.
Its only modded to run higher voltage (up to approx 18-19 volts), other than that its a regular 2500d.
Mean amp that doesn't pull much current either way... and it just gets stupid on 16v.
On that note, the amp is bulletproof and has many many more years in it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It lasts longer on the fuse he has to run for MECA.
help me out bro, your tellin me that the size of his fuse determines how long the amp will survive?? confused:crazy: //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
or it draws less current and the fuse lasts longer?
http://www.mecacaraudio.com //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif check out the rules.
And yea... its not a world of a difference, but like I said, team kicker and I'd like to run the zx2500 - always been a fan of kicker amps! The zx2500 is a bit more effeciant and a bit more bulletproof... its of course more expensive too.
Not survives, but how long it can burp at full power. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
In MECA, your class is determined by your cone area and the fusing before the amp. So the goal is to get as much power you can on the smallest fuse.
//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
btw sold.
btw sold.
And in under ~40 minutes @ that.
Spkrman
Banned
Spkrman
matteson, IL
nVRuckus
