ordered my xFire
I think you need a 1 ohm stable amp if your going to run series.. you better send back that crossfire.. It's rated @ 2 ohms, i don't know if it is 1 ohm stable.
I'm assuming tha tyour subs are dual 4 ohms. I know that was the problem w/ your old MTX, it ran at the wrong ohms, and you're just going to have that same problem again.
Get an amp that will run max power @ 1, or 4 ohms, because those are the two lowest impedences you can run w/ a single amp.
if your subs are dual 2 ohm.. Good choice. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif . But i don't know if they made the L7 in dual 2...
actually series/parallel on 2 or more dual 2ohm subs will be a 2ohm load
GrandAmGT
Grand Am GT in the Making
GrandAmGT
Central Wisconsin
MikeofTulsa
