Ordered 2 Image Dynamics ID 10" Now Box time! Box dimensions?
Guess I am confused how (since the rear deck has lots of crevesses and high and low spots to get the thing mounte up there with sealing it off the best.
you should do something like this if you are talking rear-deck installs. this is in a friends car, Lexus is300. his name is ItalynStylion here.
So is this right or no?
27" long (C pillar to C pillar)
11" wide (glass to seat)
10" deep (rear deck to trunk floor)
awesome. 1.59 cubes. so now you have to figure out what kind of cuts you need to make. well this is some voodoomath that you will get used to. i usually cut my sides of the enclosure, to the exact internal dimensions and let the other sides overlap. so- you will be using 3\4" MDF - aka .75" MDF. do NOT FORGET to add an overlap to BOTH sides. as such.
top + bottom will be the same size. since we are looking at 11x27, we need to overlap the other pieces. so we need to add .75 for EACH side we overlap.
top piece = 12.5x28.5
bottom piece = 12.5x28.5
left side = 10x11
right side = 10x11
front = 10x28.5
back = 10x28.5
Cool, but I really wanted the subs firing up in the cabin to reduce rattle. Something like that box tho!
req made a slight mistake in his math. 27x11x10=2970/1728=1.72cf. No biggie, the dimensions he gave will work fine. If you wanted to be right at .75 per sub reduce the box width to 26" external or 26.75" if you put a divider to make separate chambers.
There is absolutely no trunk rattle //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif although he did deaden the hell out of the rear deck though
i totally made a mistake. the depth of the driver is 5.5" not 9.125
i was a bit toasted that night and i made a mistake in reading that pdf.
my bad //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
hemi4me?
hemi4me?
Scottsdale, AZ
hemi4me?
