+ or - what one is what?
he has 2 black wires!!!! one solid and one with stripe, no white or red or anything else. ppl cant read,
and HAHAHA
ever look into home wiring? the black wire BITES you.
^^^ i have had first hand experiance, it does!
so it looks as if i am not guna get a solid answer ... must just have to do some trial and error and hook em up myself than eh?
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif:confused:
normally the white is hot
White is neutral and is typically just as hot as the black...don't **** with AC electricity...especially if you don't know what the **** you are doing. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
My tweets were similar but the solid color was the positive (+) and the one with the black stripe is the negative (-)...again, as long as you hook them up the same on both sides you will be fine.
thank you!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
hmm.. still havent got a clear answer!
//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif:crying://content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
For most things I've messed with when it comes to Black or Black/white stripe, is black/white stripe is negative or ground in reference to the positive. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
AeR0
AeR0
Brantford,Ontario,Canada
Ryan1126
