Opps measure twice
Ok so opps made a mistake...yaddi yaddi yaddi
Had my cuts made for an subs up port back areo port enclosure.
Opps right measurements wrong cuts or however you'd say it. My top/bottom cuts are my front / back of that makes any sense.
Any suggestions other than re-cut , since that's a known option.
[quote name='Boomin_tahoe']Tightbond
Only logical fix would be recut those pieces again. Don't want any gaps of any size.[/QUOTE]
Quote Originally Posted by Boomin_tahoe View Post
It's "oops"
Opps! it is oops opps did it again lol
Anywho... Thanks @THATpurpleKUSH I just did re cuts
Yep you're right re cuts done
Thanks for the titebond recommendation.
that's what I had planned just checking other options
[quote name='ronin1717']Opps! it is oops opps did it again lol
Anywho... Thanks @THATpurpleKUSH I just did re cuts[/QUOTE]
YW, just beware that your net volume is now smaller which will shift the port tune slightly higher. I use Titebond to glue the panels together then I use DAP Alex Plus Fast Dry to seal the inner seams. That way I know the seams have no leaks.
Ok so opps made a mistake...yaddi yaddi yaddiHad my cuts made for an subs up port back areo port enclosure.
You can make the box slightly smaller..it shouldn’t make much difference
ronin1717
ronin1717
tx
Louisiana_CRX
