Only one RCA input on my Z1
I see an input and output space for RCAs. Take some pics of what you are talking about.
yea the single is the slave/master, in/out, use the 2 rcas in the input like you normaly would , i hope....lol... so what are you the 3rd or 4th since i had it?, i was 2nd owner....lol....
Are you running it in Slave mode? If so, then you'll only receive an audio feed through the slave input/output. Switch it to master, and run the RCAs to the L/R, and you'll be good to go.
Also, if output doesn't change if you are in fact running in slave mode, and switch it. You're probably wired out of phase, check the wiring of the subs, and make sure you're properly wired.
pic up
if i plug it into the left RCA's i get nothing
if i plug one into the middle it over works my right sub
if i plug into the right i get nothing
i don't see anything about slave and master //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
EDIT: I know i don't have my gains or anything set so you don't need to mention that lol
pic up
Take it off of bridge, and put it on Pass, and then run the RCAs to L/R Bridge is to bridge 2 amps, not to bridge speaker outputs, since there is only one channel hooked up to 2 + outputs, and 2 - outputs. That's your problem.
Could possibly be a bad coil, or messed up wiring. I had the same problem when I first came into car audio, but I had a common chamber box, and a terminal on one of the subs snapped off along with the tinsel, so only one sub was being powered.
bunkerking09
Current Status: Win
bunkerking09
Kansas City, MO
PsychoTheRapist
