One rca port
Unless you have two seperate preouts, you can't directly run two amps like that off one preout.
You'll need to buy an external crossover of some kind to split the signals into the respective frequency ranges, then send them to the amplifiers.
ok do u suggest any?
Also there is a place to put another pair of rca ports but there empty is it possibe to put another 1
I assume you have a passive front stage?
I would get a 2 way Xover and use a 4 channel amp if you want to run both the fronts and rears...
I can only think of a few outboard Xover manufacturers off the top of my head right now, but I would look into Audiocontrol's offerings //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i alreaty bought a 2 channel amp.
what does a passive front stage mean?
Passive means that they are not electronically crossed over. as in, using crossovers that are pre set, rather than being adjustable.
o ok
im gunna get the audiocontrol 2xs will that work
also this goes between the hu and amp right
Yes he can if he incorporates Y-splitters into the signal path or if there are preamp outputs in one of his amplifiers....
Or if there are crossovers in the amps themselves he could use those? I know, I know - this isn't the optimal way to go about this but it is possible and potentially cheaper to do.
What kind of amp do you allready have ? Some have pass through RCA's that will acomplish what you want to do. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
PESteele
I wang on an 8 in a van
PESteele
annapolis
ramos
Mike Mccabe
