One port for 2 subs?
No man you need 2 ports for each sub!!! So you need 4!!! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Really one is fine and in some cases optimal...
As long as you're taking into consideration the port noise, then one is fine. Just don't have a small port for a lot of output. That's the only thing I would watch out for.
That would be more of a problem if he was going with two ports. Because they would be smaller than one large port...
What size subs?
1.5 Cuft per sub seems pretty small...
The subs are 12" TC-9's
I'm putting the box in a Sentra, so space is limited, what with the box, 3 amps and wiring.
Per TCSounds' website as well as REAudio's (compared TC-9 cpecs to RE's SX and SE enclosure recommendations just for the sake of comparison) they should be okay in a 1.5 cubic foot/sub enclosure. It's not optimal; 2 cubic feet is optimal. But, they both said 1.5 cubic feet per sub is okay. They said to tune the box to 32-35 Hz, btw.
Please correct me if I'm wrong in my assumption a 3 cubic foot box is okay.
I would really try and get another cubic foot, but it's up to you man, let us know how it sounds when ur finished //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My e12a.22 has a recommendation of 1.5cF ported per sub //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
And it's a TC-9 derived motor //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
FWIW.
c_hayhurst
c_hayhurst
Columbus, Ohio
JimJ
