One bat at 12.3V second and third bat at 13V Parallel problem?
timma100
I asked something similar to this a while back, but I just took a DMM to my batteries. The two I purchased from RAM are 2 years old and both sit exactly at 13V. The brand new everstart my sister bought sits at 12.3V, would I have any problems paralleling all three together? Would the everstart constantly drain my other two? Nothing is installed yet, just trying to avoid problems
The everstart is going to pull your other batteries down. Whenever you have batteries that rest differently, they usually drop down to the voltage of the lowest one. I have 4 batcaps, 1 3k and 3 2k's. The 2k's rest at about 12.8 where the 3k rest about at 13.1. But all together, they rest at about 12.8.
hmmm, so long as I don't explode my everything....
^ this
this as well as try putting a little charge on the everstart batt. might help it out a little, not saying that will fix your issue but it might bump up the everstart some
Charge the batteries before you put them. People do not realize how much of a difference this makes. Btw, if that bat is resting at 12.3v and it's brand new, you need to get a refund imo //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I completely agree, this was my sisters car, and this battery is the fifth one from walmart. The batteries before would drop to 6v when the temp dropped below 30~ degrees. This one starts the car but the starter sounds very under powered. Also they don't own a battery charger, would any charger do? or would I be better off buying a nice one.. (not from walmart)
timma100
timma100
Barksdale AFB
Buck
vegang
vegang
