Finally deciding to sale my beloved amps due to school funds. Here we have three old school SQ amps for sale. These are known to be one of the best sounding amps you could buy for money. SQ is pure and clean. First amp is a A/D/S PH15 which is a 6 channel amp, yes SIX. It's rated at 50x6 but I'm sure it does around 60w at 14.4v. Working order 10/10, looks 9/10.
Specs:
50 x 6 @ 4ohm
75 x 6 @ 2 ohm
110 x 3 @ 4 ohm mono
Stable to 2 ohms
.05% THD at rated power
Overload and Thermal protection modes
105db S/N ratio
Pics:
http://img169.imageshack.us/img169/9239/1006061551kc6.jpg
http://img175.imageshack.us/img175/2444/1006061551aed5.jpg
http://img175.imageshack.us/img175/6526/1006061551bov3.jpg
http://img175.imageshack.us/img175/4749/1006061552uc4.jpg
http://img175.imageshack.us/img175/5183/1006061552alt2.jpg
http://img175.imageshack.us/img175/2918/1006061552bhg3.jpg
Second up is a PPI Art series Ax400 4 channel amp. This amp is extremley RARE. It has a built-in crossover. Works 10/10, physical condtion 6/10. Couldn't find detailed info on this one due to the rarity of them.
Pics:
http://img208.imageshack.us/img208/2683/resized0929061143bi7.jpg
http://img208.imageshack.us/img208/4394/resized0929061144cb5.jpg
http://img201.imageshack.us/img201/8012/resized0929061150qv4.jpg
Specs:
4 x 50W @ 4 ohms
4 x 100W @ 2 ohms
2 x 200W @ 4 ohms bridged
Third one is a VERY RARE US Amps US-100HC circa 1999. Hand made in the USA. THIS IS A REDESIGNED VERSION OF THE USA-100HC which was way too big and has a fuse rating of 225A. This amp is in mint conditon except two scrathes on top as you can see in the pics but there's a reason why there's a plexiglass bottom. Please understand that the below ratings are extremely underrated and it will do over 1300wrms at 1 ohm. It has Class AB circuitry not Class D. THD of
Specs:
THD at Rated Power:
Stereo Separation: >98dB
Signal/Noise Ratio: 110dBA
Frequency Response: 5Hz-50KHz
Fuse Rating: 125 Amps
Dimensions: (Including Terminals)
62mm / 2.44in High
229mm / 9.0in Wide
451mm / 17.75in Long
Weight: 4.76kg / 10.51lb
Variable 24dB Low-Pass Active Crossover
One-Half Ohm Stable
50 Watts x 2 into 4 Ohms
66 Watts x 2 into 3 Ohms
100 Watts x 2 into 2 Ohms
200 Watts x 2 into 1 Ohm
400 Watts x 2 into ½ Ohm
200 Watts Bridged into 4 Ohms
264 Watts Bridged into 3 Ohms
400 Watts Bridged into 2 Ohms
800 Watts Bridged into 1 Ohm
Pics:
$SOLD for the A/D/S
$215 for the PPI
$360 for the US Amps
All prices include S/H.
Trades wise I'm looking for a old school quality amps that does 600-800w at 4 ohm, but I'll take anythign else into consideration. Thank you for your interest. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Specs:
50 x 6 @ 4ohm
75 x 6 @ 2 ohm
Stable to 2 ohms
105db S/N ratio
Pics:
Pics:
Specs:
4 x 50W @ 4 ohms
4 x 100W @ 2 ohms
Specs:
THD at Rated Power:
62mm / 2.44in High
229mm / 9.0in Wide
One-Half Ohm Stable
Pics:
$SOLD for the A/D/S
$215 for the PPI
