Older Rockford Fosgate Punch 55.2 two channel amplifier
Wingman0121
One Rockford Fosgate Punch 55.2 amplifier w/o end caps
Right-click on my images and select "view image" to zoom in
Got it from a friend who was running a set of components with this, works good and I just tested it at my house with a power supply. It is the ones with a removable crossover card inside and made in the US. Rated at 27.5 watts x 2 into 4 ohms @ 0.05% THD, it sounds more like double of that, kind of reminds me of my Old MTX Pro504. The included crossover card is 80Hz high or low pass or fullrange, currently I have it set at 80Hz high pass. There are a few small chips/scratches and rubbed off letters on the bottom but nothing serious, I don't have the end caps or the birthsheet. The flash probably makes the top looked better than it is but I've taken a pic of it without flash and you can see it could use some work to make it all shiny again. You'll need an external fuse for this amp and the online manual calls for a 20a fuse.
$50 shipped.
USPS flat-rate box w/tracking, it should fit in there and have plenty of cushion.
Wingman0121
Wingman0121
Wisconsin Rapids, Wisconsin
Wingman0121
