Older Rockford Fosgate 1000BD w/o end caps
For sale I have an old school Rockford Fosgate 1000bd, this thing is a powerhouse and puts out 1200 – 1300 watts at 2 ohms, it was just sitting in closet in a box, and I need the cash so Im selling it. It did work at the time it was taken out of the vehicle about 3 years ago, but I am now unable to hook up to see if it functions so selling as is. The outside of the amp is in good condition with only minor scratches, The inside appears to be fine as there are no burns or anything on the board. The specs for this amp are:
• Class bd technology
• 500 watts RMS x 1 at 4 ohms
• 1000 watts RMS x 1 at 2 ohms
• requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
• 4-gauge power and ground connectors
• 100-amp fuse and fuse holder required (not included)
• selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
• MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability.
• TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise between the head unit and the amp.
• NOMAD advanced protection circuitry monitors temperature, voltage, current and impedance, and provides "intelligent" shut-down protection without limiting system performance.
• preamp outputs for easy connection to a second amplifier
• wired remote control of Punch Bass (0-18 dB centered at 45 Hz) — gives you fingertip control of your bass impact
• POWERsync — a 6-pin mini-DIN connector that allows you to bridge together two separate Rockford Fosgate Class bd amps
• subsonic filter removes frequencies below the range of human hearing for increased efficiency
• dimensions: 14-7/16"W (10-7/8" without endcaps) x 2-7/16"H x 9-7/8"D
This amp retailed for over $400.00 when it was first released, heres your chance to get a powerhouse of an amp for a very reasonable price.
$150.00 + Shipping
Buyer will pay actual shipping
$150.00 + Shipping
