Older RE SE power handleing
600w is no sweat for an OLD SE. As long as it's not the newer Chinese version, it will handle 800w rms or so.
A good indication of the Chinese models is that the cone will say RE, then SE in smaller print on the bottom. If his is has the logos in that way, it will only take around 500w.
No sir, they were not. We rated them at 600w rms.
I stand corrected
Mounting Depth - 6.4"Mounting Hole Diameter - 9.3"
Overall Diameter - 11"
Bolt Hole Circle - 10.1"
Motor Width - 7.3"
Motor Depth - 3.4"
Basket Depth - 2.94"
Displacement - 0.14 cu. ft.
Weight - 21 lbs.
Electrical Q Value -Qes: 0.46
Mechanical Q Value -Qms: 4.4
Total Speaker Q Value -Qts: 0.42
Free Air Resonance -Fs: 26.6 Hz
Equivalent Compliance -Vas: 31 liters
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency -SPL 1W/1m: 83.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 2.8 ohm
Nominal Impedance -Znom: Dual 2/4 ohm
Thermal Power Handling -Pe: 600 W
Force Factor -Bl: 17.7
BrownVanMan
BrownVanMan
Minneapolis MN
BrownVanMan
