Old School Rockford vs Alpine
SoCaL081
50
Hey guys im wanting some input on which amp I should use with my 12" Eclipse SW8122DVC dual 4ohm sub. The two amps are a old school Rockford Fosgate Punch 360a2 and a Alpine MRP-M500. Im some what new to the this car audio and would like to hear what you guys think. Thanks
Since the sub is a d4 you should use the Alpine amp which is rated 500w at 2ohm. The Rockford is a 2 channel so you'd have to bridge the channels together but then you are limited because the amp isnt rated below a 4 ohm load bridged. Use the RF amp on some component speakers instead.
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
SoCaL081
SoCaL081
youdoofus
slater
    May 2, 2024
slater
    May 2, 2024
