old school rare rockford fosgate 18" subwoofer
mexicand
texas
What i have are some rare old school rockford fosgate 18" xlc punches rfp 2818 8ohms. i bought them from a pawnshop not to long ago. If anyone knows anything about them please share. I know their 8ohms dont know how many watts or rms they can handle. Also, looking for the best way to wire them up in my car. It would be nice to know the value of them as well. couldnt find any info even called rockford fosgate their advice was to look online because they dont have any info. They came out in 1999.
When i wire them to 4 ohms should i run a parallel and have it bridged to my amp? my amp specs for bridging is 1x2000w max @ 4ohms.
lanzar heritage 2000 watt 2 channel mosfet amp
2 x 500W RMS @ 4 OHMS
2 x 1000W Max @ 4 OHMS
1 x 2000W Max @ 4 OHMS Bridged
2 x 650W RMS @ 2 OHMS
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohm Stereo Stable
Nickel RCA Inputs
Line Outs for Left and Right Channel
Low Pass Filter Controls
High Pass Filter Controls
Power and Protection LED Indicators
Soft Turn-on/Turn-off
THD:
S/N Ratio: >90dB
Channel Separation: >65dB
Freq. Response: 10Hz~45KHz
HPF Freq. Response: 80KHz
LPF Freq. Response: 50Hz-250Hz
Subwoofer Level Control
Fuse: 40A x 1
Dimensions: 12.99''(L) x 2.24''(H) x 8.81''(W)
Sold as : Unit
Not trying to be mean at all but that amplifier is junk. I would not put an amplifier like that on those speakers. I would be looking for a quality 2 channel amp or a small Mono Amplifier what does max power at 2 ohms.
lanzar heritage 2000 watt 2 channel mosfet amp2 x 500W RMS @ 4 OHMS
Bass Boost Circuit
2 Ohm Stereo Stable
Nickel RCA Inputs
THD:
S/N Ratio: >90dB
Fuse: 40A x 1
Sold as : Unit
No you're right! I know its garbage but i didnt have an amp when i bought the subs. i ended up getting that one for free. I dont know a lot about amps and subs and their quality. I kinda know the basics. I appreciate all the help i can get. I wanna keep these 18's i have ant not have them blown or malfunction from a knockoff amp or not wired correctly. Which amp do you recommened like your personal choice for them? I dont mind not having a system installed until i can afford a decent amp. Also, what size wiring kit do you prefer i should use?
Another question for you these 18's i have are they worth trying to sell or just keeping them? A lot of people tell me they were the last subwoofers made before the square subs came out. That these 18s can perform like squares as bass wise. Is that true?
---------- Post added at 05:47 PM ---------- Previous post was at 05:47 PM ----------
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
mexicand
mexicand
texas
mexicand
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
