tracyrick
Limited035
Can't find this specific answer searching and it is worrying me.
Grounding an amp, 4 gauge wire, using the bolt that secures my front seat to the chasis. Subaru Impreza.
- The painted seat frame sits directly on the chasis, no washers in between
- The 2 flat washers for the bolt sit between the bolt head and the seat frame
If I put my ring terminal between the 2 washers, is that a good ground? Essentially makes the ring terminal connect to the chasis via the washers/bolt.
Or do I need to put the ring terminal between the chasis and the seat frame? That seems like a crappy connection point because I don't think the seat frame rests perfectly flat against the chasis...
