anger
So I just got a new amp...here are the specs:
001399: MEMPHIS 16-SRX 1.500$1,399.00 TT
One question I have is, if this is a mono block amp, why are there stereo inputs and outputs for 2 channels?
Also, after reading some FAQs on crutchfield's website, I'm wondering if I can safely run a 2 ohm load in a bridged configuration with this amp. It states that it's stable at 2 ohms with 500 watts, but not sure if that means I should wire 2 subs to one channel and the other 2 subs to the other channel..which would be running at 4ohms (I'm running 4 svc 8ohm subs)
Let me know if anymore info is needed for you to help. Thanks!
