Official CarAudio.com Big 3 Thread
has anyone done the big three on a durango from 00-03?, im just wondering how to connect everything to the battery as in the existing wires and the new ones
ok...dumb question, lol, but its my first time doing this...if the wire does not run THROUGH the fuse holder...then how is the electrical current passed through it?
I'm not understanding your question... If no fuse is there for the electricity to run through, it just runs straight through the wire... Am I missing something here? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Oh wait a minute, I think I get what you are saying. See, you aren't understanding the concept of fuses. Electricity DOES run through the fuse in the fuse holder, but if too much goes through, then it pops the metal piece in there, so no more electricity can run through the line. Get it?
Get yourself some crimpable ring terminals and go at it. Add the rings to the stock battery terminal.
ok...last question from me...
heres the game: Find My Alternator!
2003 tacoma
the alt has a wire running from the (-) terminal on the battery to it but no positive from alt to battery. The positive terminal has 2 wires coming off of it. One goes straight to a fuse box and the other has a plastic connector on the end and plugs into a connector under the fan belt. Any help with what i should do here?
it's hard to follow in a small foriegn car...that doesn't look like it in the pics disturbedfuel posted, but follow the belt it should be easy to find
May I enquire about what belt you are talking about? There's more than one belt in a car, and this may confuse him (no offense crazy4ozs). If you meant follow the positive wire coming from the battery, I already said that, and I don't understand why you needed to post. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif When I say it, it needs to be confirmed by someone with a higher post count than me?
i would but the ring terminals don't fit on the stock battery terminals and i dont want to buy two aftermarket ones
Too bad so sad then. The Big 3 is not for you, and you need to sell all your equipment for cheap. Buy some new battery terminals. They're cheap.
Knowing what it looks like will help you find it. Google "Alternator" in the images section and that should help out.
2003 tacoma
Keep following the guide. Remember, you're not removing the stock wires... your adding more to them.
My question is though, wouldn't this work better if it just went from battery (-) to chassis, and then another battery (-) to engine block? If anything, it would provide the same results, theoretically, correct? That's actually the way I have it set up right now, and depending on the answer I get, I will decide whether or not it is worth the time to switch it around or not //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have a GM double post as well and felt this was a "factory" way to complete the big 3. Did it work out well? Did you ever try it another way?
It did work out well, I haven't had any dimming issues, and I noticed my alternator belt doesn't sound like metal against metal as much anymore because it's running more consinstently. The volts never drop below 13 any more, and my windows actually go down fairly quickly, even with the sub and amp booming //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
johnecon2001
SSA/ROE Super-Møderator
johnecon2001
Phoenix, AZ
2023 LTZ
