I'm not understanding your question... If no fuse is there for the electricity to run through, it just runs straight through the wire... Am I missing something here? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gifok...dumb question, lol, but its my first time doing this...if the wire does not run THROUGH the fuse holder...then how is the electrical current passed through it?
has anyone done the big three on a durango from 00-03?, im just wondering how to connect everything to the battery as in the existing wires and the new ones
May I enquire about what belt you are talking about? There's more than one belt in a car, and this may confuse him (no offense crazy4ozs). If you meant follow the positive wire coming from the battery, I already said that, and I don't understand why you needed to post. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif When I say it, it needs to be confirmed by someone with a higher post count than me?follow the belt it should be easy to find
Too bad so sad then. The Big 3 is not for you, and you need to sell all your equipment for cheap. Buy some new battery terminals. They're cheap.i would but the ring terminals don't fit on the stock battery terminals and i dont want to buy two aftermarket ones
Knowing what it looks like will help you find it. Google "Alternator" in the images section and that should help out.ok...last question from me...
heres the game: Find My Alternator!
Keep following the guide. Remember, you're not removing the stock wires... your adding more to them.2003 tacoma
the alt has a wire running from the (-) terminal on the battery to it but no positive from alt to battery. The positive terminal has 2 wires coming off of it. One goes straight to a fuse box and the other has a plastic connector on the end and plugs into a connector under the fan belt. Any help with what i should do here?
My question is though, wouldn't this work better if it just went from battery (-) to chassis, and then another battery (-) to engine block? If anything, it would provide the same results, theoretically, correct? That's actually the way I have it set up right now, and depending on the answer I get, I will decide whether or not it is worth the time to switch it around or not //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
