Oa
So if i threw in 2 apsm1300s with 1/0 wiring to both and a 800-1000 cranking batt in the back and then put the OA 12's wired at 1 ohm, in a 3 cubed box at 33 htz. What about that?
1/0 to a 1000 watt amp? lil excessive.. not to mention it only accepts 4g lol
but also if the subs are dvc4 each sub amp combo can only be wired at 2 ohms per... unless they strap... either way same power..600 per sub...
APSM-1300
• 300W RMS@4 Ohm (
• 600W RMS@2 Ohm (
• 1000W RMS@1 Ohm (
bigger box will make the lows better.. and on ur small power I would highly recommend bigger box...
Distrobution blocks man. And they are both one ohm stable. so if i run two of them and wire both subs to one ohm. It would be 1 amp per 1 sub. Thats my intentions
---------- Post added at 12:08 PM ---------- Previous post was at 12:08 PM ----------
Im buying a 50 foot spool so i can do my big 3 at the same time
I dont think the apsm's will take 0 ga. They only draw enough current to need 4. You could do a 0 to distro block and split it into 2 4ga's. And I hope the battery you are looking to add isn't a starting battery, you want to use a deep cycle battery with a low esr.
What do you guys think would be a good box build for 2 d4 obsidian audio's? They are going into a 2003 mustang. They will also be powered by 2 apsm-1300's. Help please
you really have no fkin clue do ya dude?
and it is obvious you cant read either...
YOU CANT WIRE A DVC4 SUB TO 1 OHM!!!!
got it now asshat?
Gbob2003
Great Odens Raven
Gbob2003
Marine corps base hawaii
Gbob2003
