Now what?
thepope3290
I built the box you guys recommended for my two 12" Type R's, which is 5 cubes at 32 hz. I have all the pieces put together...now all I need to do is cut out the circles for the subs and some openings for wiring, right? Is it true that I need a piece of wood to separate the two subs inside?
no you do not need a divider (board to sperate them). so yeah all you have to do is cut out the circles for the subs and for the wire. you could, however, run your wires through your port to your speakers and then to your amp and that will make it so you dont have to make other cutouts, but it is totally up to you. but just make your speaker cutouts and wire them and your good
i do what pickup1 said works great //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thepope3290
thepope3290
Thomson, IL
Rawr-DQ
